Can't update I3 mk3 firmware from Linux laptop
MCWalkman
(@mcwalkman)
Trying to update the latest my I3 mk 3 with the latest firmware update prusa3d_fw_MK3_3_4_0.hex . When I do, I get the following error "avrdude: ser_open(): can't open device "/dev/ttyACM0": Permission denied"
I am using a Linux laptop running Umbuntu Gnome.
I have restarted both devices several times without any change.
I would appreciate some guidance, thanks.
Napsal : 04/10/2018 4:13 am
lutz.b2
(@lutz-b2)
Re: Can't update I3 mk3 firmware from Linux laptop
Please check, if your user is in the "dialout" group. This will give you permissions for the serial ports.
Napsal : 04/10/2018 11:02 am
MCWalkman
(@mcwalkman)
This almost helped, you were definitely on the right track.
My son, who is my Linux expert, had to give Linux permission to write to the device. This ended up working
Thanks for the advice.
Napsal : 10/10/2018 2:13 pm
Patrick McNamara
(@patrick-mcnamara)
sudo chmod 666 /dev/ttyACM0
This assumes you have the ability to run things as root with sudo. That will fix things in the immediate term. Look at group that /dev/ttyACM0 is owned by. Here is an example for /dev/ttyS0 as I'm not at a machine with a printer connected.
$ ls -ld /dev/ttyS0
crw-rw---- 1 root dialout 4, 64 Sep 19 23:01 /dev/ttyS0
As someone else mentioned, the dialout group is a common group to own communications ports. So long as the group is not root, you can permanently fix the problem by adding yourself to that group. Different distros have different user management UIs where you can set your group membership, or you can edit /etc/group and add yourself to the group. Find the group and add your userid at the end of the line. If there is already a user id there, then separate with commas.
*edit* missed the last posted noting it was fixed. Congrats. Will leave the rest of the above in place for future souls who come searching.
Napsal : 10/10/2018 9:17 pm
