Can't Load files onto SD card
thedavinator37
(@thedavinator37)
I recently got my Prusa kit and assembled it. All of the tests went fine, and all of the test prints from the Prusa SD card worked. However, I tried uploading some of my own files to the SD card and it said that the SD card cannot be overwritten. When that didn't work, I tried a different SD card. All of the files went onto this card, but when I put it into the slot in the printer, the files did not show up under the "print from SD" tab. Any thoughts? I already put my files into a slicer beforehand and converted them to gcode.
Opublikowany : 27/12/2018 7:15 pm
thedavinator37
(@thedavinator37)
Re: Can't Load files onto SD card
Nevermind, just had the SD card locked
Opublikowany : 27/12/2018 7:29 pm
jimwes55
(@jimwes55)
RE: Can't Load files onto SD card
David, how do you load a new print to the sd card in the first place?
Opublikowany : 10/09/2019 12:48 am
