Can not run TM calibration with Revo6 hotend
mhacker
(@mhacker)
I just upgraded to 3.13.1 and whenever I start the TM calibration it just moves to the middle of the print bed and heats up the hotend to 65-70 degrees and then aborts with a "Print aborted" message.
Anyone else who ran into this and were able to solve it?
I have the correct firmware (the printer identifies as "MK3-R" on the main screen)
Postato : 07/10/2023 9:14 pm
mhacker
(@mhacker)
RE: Can not run TM calibration with Revo6 hotend
The PID calibration also does not work. It seems like it's attempting to heat up the hotend to 230 degrees but it stops at 65 again and then just let it cool down. The display says "PID cal. 0/5" so it looks as if it's still waiting for the hotend to heat up.
Postato : 07/10/2023 9:21 pm
Jeremy Pislot
(@jeremy-pislot)
Utenti
Posted by: @mhacker
I have the same problem, I follow your post.
Postato : 08/10/2023 9:57 pm
Gritomatic
(@gritomatic)
Utenti
3.13.1 + Revo is a total failure. I updated the firmware on three MK3 units in good condition:
  1. "Print aborted". Thermal calibration fails in the beginning.
  2. "Thermal error".
  3. "Thermal anomaly".
Postato : 09/10/2023 3:38 pm
galactic
(@galactic)
I have a similar problem. I tried ` e3d_REVO_fw_MK3_MK3S_MK3S+_3_13_1_6876.zip` from their GitHub repo, but continuously get false "Thermal Anomaly" errors. On my machine, I am able to run the calibration, but during the print it beeps every few minutes.
On my end:
Does anyone have any further resources / troubleshooting steps for eliminating this behavior?
Postato : 10/10/2023 3:33 am
Jeremy Pislot
(@jeremy-pislot)
Utenti
I have a trianglelab mk3S with easy rambo 1.1b,  I updated the firmware with "MK3S-R" 3.13.1 + Revo (40W) it's a total failure.
If I flash with "MK3-R" 3.13.1 + Revo (40W) , I am able to run the calibration, but filament IR sensor doesn't work (that's normal because there is difference between mk3 version).
I think there is something which is wrong on this version 3.13.1 + Revo.
I downgraded to 3.11, that's work.
Be patient version "3.13.2 + Revo" ?
Postato : 11/10/2023 10:40 pm
