Can I use the other side of this spring steel sheet?
Ragnarx
(@ragnarx)
When removing the most recent print, some of the PEI layer came off a spot on my sheet. The other side is fine. Can I use the other side for prints or will the damaged PEI layer cause damage (sticking?) to the heated?
Publié : 08/10/2023 4:15 pm
Hello
(@hello)
RE: Can I use the other side of this spring steel sheet?
Posted by: @ragnarx
I removed one the pei from one side of my plate once it got damaged cleaned it and used the other side but yours dosent look very big of a hole so I'd say your fine to use the otherside
Publié : 08/10/2023 10:44 pm
1 personnes ont aimé
Unless the patch is huge it should be fine - if it is huge strip off the rest to make it level first.
This is why the sheets are double sided.
Publié : 09/10/2023 2:36 am
