Can I read and write the current "Live adjust Z" using G-Code?
EsotericMaker
(@esotericmaker)
Can I read and write the "Live adjust Z" using G-Code or can it only be done from the console?
If the former,
  • What G-Code is used to read the current "Live adjust Z" level?
  • What G-Code is used to write/change the current "Live adjust Z" level?
  • What is required to write the changes to flash?
Napsal : 02/02/2023 2:02 am
