Calibration fails - PINDA triggers 5.5 cm above bed
twam
 twam
(@twam)
Hi everybody,
I have a problem with my PINDA probe which seems to trigger about ~ 5.5 cm above the bed. (see http://misc.twam.info/images/prusa3d.com/prusa_i3_mk3_pinda_offset.mov ). This results in a failing Calibration and thus printing is impossible.
Yesterday the printer was printing fine and I problem appear today after running a first layer calibration. I updated to Firmware 3.3.1 a few days ago. Any help/suggestion is appreciated.
Best regards
Tobias
Napsal : 22/07/2018 3:37 pm
Olef
 Olef
(@olef)
Re: Calibration fails - PINDA triggers 5.5 cm above bed
Your Pinda is faulty or its wire has a break in it. Try wiggling the cable bundle when it is at the spot where it triggers. Either you will need to replace it or in the case of the wire break trace and repair if you wish. Good luck!
Napsal : 23/07/2018 7:57 am
twam
 twam
(@twam)
Hi Olef,
I tried already wiggling the cable, but it doesn't make any difference. Also the spot it trigger faulty is quite 'constant'. If I switch off the printer, move the print head, switch on again und restarting calibration it ends up in the same position.
Unfortunately spare PINDAs seem to be out-of-stock in the Prusa shop. 🙁
Best regards
Tobias
Napsal : 23/07/2018 7:39 pm
Olef
 Olef
(@olef)
Chat with support. They may be able to rob one from production for you as your printer is out of action. Worth asking the question!
Napsal : 23/07/2018 11:12 pm
twam
 twam
(@twam)
Replaced PINDA probe and now everything works again! Thanks for the help!
Napsal : 27/07/2018 7:26 pm
Olef
 Olef
(@olef)
Glad you got sorted. Good luck!
Napsal : 27/07/2018 11:04 pm
