Cable for LCD screen mk3s+
Kenyiro34
(@kenyiro34)
I have a question about the length of the cable from the LCD to the Prusa mk3s+ printer (I want to install an LCD screen outside in Ikea lack and I have a question whether the cable can be longer than the original one) because it is a bit short.
Napsal : 18/02/2025 12:04 pm
Robin_13
(@robin_13)
RE: Cable for LCD screen mk3s+
Hello, Kenyiro34.  Yes it can.
Look at the instructions for the Prusa enclosure where the control panel is mounted on the outside.
If your cables are not long enough, you  could make your own if you order the correct connectors and ribbon cable.  You may be able to order pre-made cables.  Connectors and cable is not that expensive.  If you are handy, you may be able to find some very old computer ribbon cables that are long enough to strip.
If you are very careful, you can remove the connectors from the ribbon cable and reuse them.
Napsal : 22/02/2025 4:44 am
