Burnt out extruder heater
raco66
(@raco66)
I burned out my extruder heater. Had a brand new V6 unit, so fitted according to instructions. Still no heating! Checked the 3 fuses, all OK.  Checked all push in connectors. - Nothing?
Anyone offer any suggestions please. Can I meter out the heater and thermister cables to search for the problem?
Or have I somehow damaged something on the control board?
Most grateful for any suggestions.
Posted : 03/09/2021 2:35 pm
Please clarify:
Does the printer  entirely fail to start?
Or does it start but fail to heat?
Posted : 03/09/2021 3:47 pm
raco66
(@raco66)
Heater extruder.
Everything including the platen heat works OK until I try to heat the new extruder and it remains ambient. The sensor flicks a couple of degrees so is probably OK, but no heat to the extruder cartridge.
Posted : 03/09/2021 3:54 pm
Double check the hotend fuse, the upper 5A nearest the hotend socket.
Check the hotend socket itself, repeated plugging might have broken a connection...
I don't have the correct value to hand but the heater should show a low resistance to a multimeter, not zero.
Posted : 03/09/2021 4:21 pm
raco66
(@raco66)
Hotend heater
Thanks!  I will check everything over once more and then meter the terminals.
Posted : 03/09/2021 5:15 pm
raco66
(@raco66)
Hotend Heater
Thanks Diem.  Turned out it was a bad contact on the fuse socket. Cleaned with contact cleaner and IPA. all working.
Obliged for your assistance.
Posted : 04/09/2021 9:38 am
