Broken X end motor-idler BL for mk3
chris.t25
(@chris-t25)
I was adjusting my x-belts today and cracked the X end motor-idler 🙁
Do I need to take the whole printer apart to replace the part?
Napsal : 27/09/2020 6:07 pm
RE: Broken X end motor-idler BL for mk3
I had a similar issue and I took it apart.
Napsal : 29/09/2020 12:46 pm
Posted by: @chris-t25
No, not required. You only have to remove the X-axis from the Z-axis (remove top holder) and possibly remove some cables from the extruder so that you can lift the X-axis above the Z-axis. The x-axis idler part is just plugged on.
Napsal : 29/09/2020 1:11 pm
chris.t25
(@chris-t25)
@karl-herbert
Phew, that's good to know. I was dreading a complete teardown.
Napsal : 29/09/2020 1:41 pm
@chris-t25
Maybe this video could help:
Napsal : 29/09/2020 2:04 pm
