Broken heatbreak on MK3
Alaingeenrits
(@alaingeenrits)
I send this message to Prusa support last week, but they might be busy. So looking for input here...
While exchanging nozzles on my MK3,  I broke the heatbreak between heater block and heatsink. Accidents happen… I looked up the spare parts on the website and also the procedure, but I was wondering if you have experience or tips on what to replace? A piece is still stuck in the heater block, so I guess I need to replace it too, but I am nervous about disconnecting the thermistor from the old one after all these years… Afraid I will break the wires and do not see the thermistor in the spare parts… Please advice…
Publié : 05/12/2021 5:42 pm
BogdanH
(@bogdanh)
RE: Broken heatbreak on MK3
Can't be seen on photo, but have you tried to unscrew nozzle first? After that it should be easier to unscrew the bit that's left from heatbreak.
Btw. You can get thermistor for MK3 on free market. Here's one store.
[Mini+] [MK3S+BEAR]
Publié : 05/12/2021 7:47 pm
To make it easier to remove the elements, I would heat up the heater block with a heat gun.Heatbreak, e.g. made of titanium, is also available from other dealers near you. I would also order a thermistor (ATC Semitec 104GT-2 104NT-4-R025H42G) at the same time, as these tend to break.
wbr,
Karl
Publié : 05/12/2021 10:04 pm
Alaingeenrits
(@alaingeenrits)
Thanks! Yes I did but it broke of and cannot get a grip. Thanks for the shop, did not know it.
Publié : 06/12/2021 7:41 am
Alaingeenrits
(@alaingeenrits)
Thanks for the tips!
Publié : 06/12/2021 7:54 am
