Box for 3D Printer - help! (plexiglass thickness issue)
Hi Everyone,
Couple of weeks ago, I have purchased an i3 MK3S printer and I love it! Recently I have started experimenting with other materials (beside PLA) as well, but I ran into some issue with warping.
Found this awesome article with instructions on how to build your own custome 3D printer box from scratch - and I have decided to build it myself.
https://blog.prusaprinters.org/cheap-simple-3d-printer-enclosure/
I have purchased everything on the list, but I have encountered an issue with the plexiglass thickness - for some reason, I could not find many clear plexiglass with 3mm thickness (which is mentioned in the article), in most of the places I have looked, they have either 2mm or 4mm (in Czech Republic BTW), so for that reason, I have purchased the one with 4mm thickness.
In the the article, there are links to download the printed parts, but there are designed only for the 3mm thickness - and since I am pretty new to 3D printing, I dont know how to adjust them, so they will be useable for plexiglass with 4mm thickness...
Can anyone please advice me, how can I adjust the printed parts for the box, so they can be used for the 4mm thick plexiglass?
Thank you!
RE: Box for 3D Printer - help! (plexiglass thickness issue)
There are many remixes of the original enclosure on thingiverse already so you dont need to alter the parts yourself. Try https://www.thingiverse.com/thing:2776584 which has 3,4,5 & 6mm variants. Spend some time looking at all the options on there.
