Boot Loop
Alan747
(@alan747)
Boot Loop
After upgrading my MK3S printer to the MMU 2 option. i was able to do a few prints; however starting today i am having a boot loop every time i connect the USB port to the computer.
I already try multiple reboot as well as different USB cables and USB ports. same results.
Publié : 10/07/2020 5:18 am
RE: Boot Loop
Posted by: @lopala
Hallo and welcome in Prusaforum,
i assume you also flashed the correct firmware to MK3S/MMU2S. https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_9_0_MK3S_1_0_6_MMU2S.zip (S upgrade!!)
A reset when connecting the usb cable to the computer is normal, but not a reset loop. Maybe you are testing another computer or maybe there is an error in the Einsy USB connection. Driver update often helps too.
good luck!
Publié : 10/07/2020 1:09 pm
Alan747
(@alan747)
RE: Boot Loop
@karl-herbert
Thanks
All drivers and firmware are up today. I started having the issue once i upgrade to the MMU2S.
I was able to track the issue to one computer. the others are not having this issue. I am preparing to use octoprint.
Publié : 11/07/2020 11:45 am
