Bondtech gear grub screw
tre4b
(@tre4b)
I'm having a challenge with the bondtech drive gear coming loose.  I've tried to tighten it but I think the grub screw may have a damaged hex socket and thus never fully tightens.
Can anybody tell me the specs of the grub screw so that I can source a replacement to see if that resolves the problem without buying a whole new gear set as being UK based shipping costs silly money right now.
Respondido : 17/07/2021 7:19 am
Miembro
answer
Welcome to the forum:
I did not know, but Google did:
https://www.bondtech.se/product/setscrews/
I hope this helps.
Respondido : 17/07/2021 9:22 am
1 les gusta
Ringarn67
(@ringarn67)
RE: Bondtech gear grub screw
@cwbullet
There is three options, M3x2, M3x3, M4x3?! 🤔
@tre4b
M3x3! 👍
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Respondido : 17/07/2021 12:34 pm
1 les gusta
Miembro
RE: Answer
Posted by: @ringarn67
@cwbullet
@tre4b
M3x3! 👍
Yes and the answer is there.  The key is know which one you are replacing.
Respondido : 17/07/2021 1:20 pm
1 les gusta
tre4b
(@tre4b)
ta
I found the bondtech ones but could only buy the whole set for £30 seemed a lot of money.  Thanks for the help though.
Respondido : 03/08/2021 12:58 pm
Dan Rogers
(@dan-rogers)
Try grub screws from X or Y axis spares
I bought a set of spare pulleys when I did the moons stepper motor upgrade - you can get 6 pulleys for about 5 bucks.  Each of them has 2 grub screws in them that should be a match.  They aren't special either - just search setscrews M3x2mm in any tool catalog and you should be able to get a hundred of them pretty cheap.
Respondido : 03/08/2021 1:08 pm
