Bondtech firmware removal
Grimstod
(@grimstod)
I have a Prusa 3i that I purchased from another user and he had the Bondtech extruder on it. I set it back to the original factory configuration because I need all my printers to have the same parts. Now though the motor runs too fast. I suspect a firmware issue? I know you have to modify the firmware to install a bond tech.
How do I modify it back to its original Prusa speed in firmware? I already did a firmware update on the machine once. It still pushes out extrusion 3x faster then it should. So a firmware update did not reset it.
Veröffentlicht : 23/05/2022 8:45 pm
RE: Bondtech firmware removal
Factory reset and choose delete data option
Veröffentlicht : 24/05/2022 8:09 am
Grimstod
(@grimstod)
Thank you this worked like a charm. I also used this video as a guid to doing the reset.
Veröffentlicht : 24/05/2022 1:56 pm
glad to help
Veröffentlicht : 24/05/2022 3:49 pm
