Black on the z-axis threaded rod
Virtech
(@virtech)
Is this normal wear and tear on the z-axis threaded rod?  If not am I missing some maintenance step to keep this from wearing out?
Thanks for any assistance =D
Postato : 19/12/2021 11:23 pm
Utenti
RE: Black on the z-axis threaded rod
This is probably grease.  How old is the printer?  Did you assemble it yourself?
Postato : 20/12/2021 12:18 am
Swiss_Cheese
(@swiss_cheese)
@virtech
I'm not sure if it's some kind of Oxidization, or if it's dust and dirt from the environment trapped in grease, but I have that same build up of black in the areas that the Trapezoid nut axis travels in, and I think the grease attracts a certain amount of dirt and holds it, however it does not appear in the areas below the range of travel, (they are still shiny). I believe the threaded rods are nickle coated so they should be fairly resistant to Oxidization. on my oldest machine they are black even though I do regular maintenance, 5 years and several 10's of thousands of hours in and no problems that I can associate with this to date.
I use a paper towel and a mild degreaser on them to clean before greasing again during maintenance.
Just my thoughts and observations, I've wondered this myself. I own three Machines in the MK3 series.
Regards
Swiss_Cheese
The Filament Whisperer
Postato : 20/12/2021 3:38 am
Utenti
That makes sense.  I clean my threaded rods once a month and do not have this.
Postato : 20/12/2021 9:08 am
BogdanH
(@bogdanh)
I think black are remains of friction between trapezoidal nut and rod. I would guess, that friction increases if trapezoidal nut is tightened fully with those two bolts (trapezoidal nut should have a little "free play").
[Mini+] [MK3S+BEAR]
Postato : 20/12/2021 9:41 am
Virtech
(@virtech)
This was my thought too, didn't know if I needed to have a spare set of the trapezoidal nuts on hand in the event it wears too much.  As other have mentioned I'll just start cleaning the threaded rods from now on.
Thanks all for sharing your knowledge =D
Postato : 20/12/2021 1:16 pm
