Better hotend cooling mod?
laskr1999
(@laskr1999)
Utenti
I have an Dragon HF hotend with ceramics heatbreak. My main problem is, that over 30c ambient I cannot print pla, below that if i print it faster, I can, if not I get heatcreep clog. Any way to make the hotend cooling better? I have a sunon 7k rpm 5V fan already installed, before that PLA was no go as it heated up way faster. Now trying to make a narrower mod that directs airflow to the core of the hotend, but that makes a little weak airflow.
Postato : 20/06/2024 8:04 pm
RE: Better hotend cooling mod?
Have you tried the experimental menu?
https://help.prusa3d.com/article/experimental-menu-mk3-s-_161213
Postato : 21/06/2024 12:22 am
laskr1999
(@laskr1999)
Utenti
It was set in there too, yes. But right now having klipper on the printer, but the hotend cooling is not enough
Postato : 21/06/2024 5:19 am
