Belt tension - different results with old and new method (MK3S+)
Hello everybody,
I hear a noise in one end (appr. last 5 cm) of my y axis of my MK3S+, that's why I checked the belt tension. Unfortunately I got different values with the old and new method:
Old method (running belt test from LCD menu):
x: 243 --> too tight
y: 265 --> ok (in direction to tight)
New method (belt tuner app):
x: 96 Hz --> just right
y: 93 Hz --> too loose
Which one is the more correct one?
BR
Oliver
Postato : 21/12/2023 6:13 pm
RE: Belt tension - different results with old and new method (MK3S+)
Of all the methods I actually found the use of the belt tension gauge https://www.printables.com/model/46639 the most reliable.
Postato : 22/12/2023 10:30 am
