Bed Temperature Rising 5 Degrees Higher Than Input
I recently had to change the thermistor on my bed.
I put the new one in, and I'm having an issue with the temperature. Right now I'm printing TPU with the bed temp set at 50. Every once in a while, the bed temperature will slowly start rising to 55 degrees, then fall back down to 50. This happens every 10-15 minutes or so. I've changed the thermistor in the bed before, but never had this issue. I tried doing a PID tune on the bed, but that didn't help.
Any idea how to fix this?
Publié : 22/12/2021 12:38 am
