Bed Temperature 10c colder than reading?
Quacker
(@quacker)
Hi!
I was having adhesion problems and decided to measure the bed temperature with 2 different far-infrared sensors. They both agreed that when the temp is set to 70, the bed was actually about 60c
Can this annoyance be adjusted out or am I going to have to make a table to compensate each setting manually?
Regards -
Este debate ha sido modificado el hace 5 years por Quacker
Respondido : 10/06/2021 9:43 pm
RE: Bed Temperature 10c colder than reading?
Posted by: @quacker
Hi!
Regards -
Hello and welcome to the Prusaforum!
Have you ever done PID tuning?
There is also an article on this topic here: https://github.com/prusa3d/Prusa-Firmware/issues/2642
wbr,
Karl
Respondido : 10/06/2021 9:57 pm
Quacker
(@quacker)
Thanks for the quick reply.
This is a working printer, not a hobby item. I really don't have time to stop and mess with things, especially since it wasn't a cheap printer and getting temperature regulation right is normally a very simple matter. Nonetheless, I am glad to see that I'm not the only one that is having problems. Until Prusa has a front an center fix, I'll sidestep the issue by making an offset table for both the bed and nozzle.
Regards -
Respondido : 10/06/2021 10:23 pm
