Bed level visualization without octoprint plugin?
Mustrum Ridcully
(@mustrum-ridcully-2)
Using the no springs method with nylock nuts
https://github.com/PrusaOwners/prusaowners/wiki/Bed_Leveling_without_Wave_Springs
there was posted some time ago where the G-81 results could be dumped into a linked webpage that would generate the heat map but I can't seem to find this "no Octoprint method" other than some folks just say use Excel so if someone could post that webpage it would be helpful as I have neither octoprint or excel.
Napsal : 30/01/2019 10:02 pm
thrawn86
(@thrawn86)
Re: Bed level visualization without octoprint plugin?
there are several out there, this one works
http://www.stefanocottafavi.com/3d-printer-bel-level-visualizer/
not a big fan of nyloc method, seemed kinda hacky.
Napsal : 31/01/2019 5:23 am
Mustrum Ridcully
Thanks Curtis, I don't see another way to fix printing close to all the edges of the build plate. I have a bunch of full plate sized prints to do this weekend and if I have good first layer on one side I am air printing on the other edge even with the max correction dial in on each edge.
Napsal : 31/01/2019 6:17 pm
Whilst bed level correction is limited to +-50 microns. There is a gcode which enabkes values +80 to-80
Rwgards Joan
Napsal : 31/01/2019 6:38 pm
