Bed level terrible all of the sudden.
Printnado
(@printnado)
Hi, I have a second hand i3 mk3s that i purchased some months ago. Printer only had 20 hours of print time on it when i got it, had to apply some grease to the bearing since they were dry from sitting in storage. Anyway, printer has been printing great for months and a couple of days ago i checked the bed mesh visualizer of Octoprint and noticed the bed on the right side is significantly higher than the left side. I tried to manually move the X gantry all the way up and re align but nothing changed. Whenever im printing something in the front right corner the first layer is rough, I have also tried to retighten the bed screws with no luck. Image of the bed visualization. Can anyone point me in the right direction?
Opublikowany : 04/10/2021 7:02 am
Dr
Are the smooth rails seated properly in the Y axis rail cups?
Opublikowany : 04/10/2021 7:12 am
Printnado
(@printnado)
Y-axis seems fine
As far as I can see nothing changed visibly on the Y-axis rods, still tied down and seated properly.
Opublikowany : 04/10/2021 2:45 pm
hmmm.... Curious!
Opublikowany : 04/10/2021 8:01 pm
jwvaughn
(@jwvaughn)
Tiny piece of crud
I suggest checking both the heating plate and the underside of the build plate to see if there is a bit of crud.  I have had tiny wisps of filament get stuck between them and throw the bed level off.  Sometimes a print gets strange and others the bed leveling routine fails.
jwv
Opublikowany : 05/10/2021 5:37 am
Printnado
(@printnado)
Still no luck
 Ive cleaned both sides of the build plate, top size of hot plate and cleaned the rods, still no dice.
Opublikowany : 06/10/2021 4:52 am
