Bare wire for hotend is exposed, was rubbed off from printing
RoshyRu
(@roshyru)
The other day I noticed that one of the wires for the hotend had been rubbed away, exposing the metal wire. It was even causing some of my prints to burn. I had pulled it back and out of the way again, and I was able to finish a print just fine after. I can add some pictures later if that helps.
So my questions are as follows: How should I repair this? Would heatshrink tubing work? Would electrical tape work? Would either of those stand up to the heat of the wire?
Publié : 05/08/2020 1:07 pm
RE: Bare wire for hotend is exposed, was rubbed off from printing
Posted by: @nanda1123
In case of damage to the thermistor or the heating cartridge I would rather replace it.
For stripping I would rather use glass fibre sleeving instead of heat shrink tubing.
https://www.mcmaster.com/fiberglass-sleeving/
Publié : 05/08/2020 2:06 pm
RoshyRu
(@roshyru)
After looking at it closely I did notice that it was the thermistor wire that is exposed, not the heater cartridge as I initially thought.
Publié : 05/08/2020 2:26 pm
