Bad Print Fail, broken parts
TRA Designs
(@tra-designs)
Had a bad failure and it broke the heat cartridge wires and the fan and heat shroud. First failure I’ve had since I got it about 4 months ago. I can print the new shroud, and I believe I can get the fan and heat cartridge from E3D. Any help on specs would be greatly appreciated.
Respondido : 03/10/2018 2:46 am
TRA Designs
(@tra-designs)
Re: Bad Print Fail, broken parts
Fan is ok, just the “rtd” or thermocouple I believe. Assuming the larger cartridge is the heater and the front is the thermocouple...
Respondido : 03/10/2018 3:40 am
TRA Designs
(@tra-designs)
Thinking this is what I need.
Respondido : 03/10/2018 3:45 am
thrawn86
(@thrawn86)
nope, thats a thermocouple and is a totally different animal.
you need a cartridge style 100k thermistor, which you can get from prusa, e3d directly or e3d via amazon : https://shop.prusa3d.com/en/mk3-printer-parts/205-mk3-hotend-thermistor.html
prusa direct is the only one i can find that has the right molex connector, otherwise you can just splice on the old one.
same story with the heater, any 24v cartridge will work and with the heater you will not need a special molex since it uses screw terminals
Respondido : 03/10/2018 5:25 am
