Bad drifting
xijio
(@xijio)
Bad drifting
I built the i3 mk3 a few weeks ago, during the build I broke the x-axis idler assembly. Prusa took mercy on me and sent me a new part. Before I replaced the parts I could print mostly fine, but I did have some layer shift. I attributed it to the part I broke. Well after replacing the x-axis idler assembly I printed a calibration cube and it got worse:
https://imgur.com/gallery/IXGOi5f
Any ideas what I should check first?
Napsal : 19/08/2018 12:20 pm
xijio
(@xijio)
Re: Bad drifting
BTW, running firmware 3.3.1
Napsal : 19/08/2018 7:49 pm
xijio
(@xijio)
Re: Bad drifting
It ended up being the x axis motor's set screws weren't tight:
Before and After:
https://imgur.com/a/CMVfHi8
Napsal : 19/08/2018 9:09 pm
Olef
 Olef
(@olef)
Re: Bad drifting
Thanks for posting the answer 🙂
Napsal : 19/08/2018 10:14 pm
