Axis Calibration Midprint
Hello everyone,
A fast one,
While printing Polymax-PC a big item (it is printing as we speak) I noticed that every few layers the printer stops to recalibrade the Y-X axis and then continues the printing.
Any idea why? Other than this the print is progressing and printing perfectly for the time beeing.
Thanks
RE: Axis Calibration Midprint
Hello everyone,
A fast one,
Thanks
Usually he does this if he loses position due to stiff axes or a crash with the printpart. Did you activate crash detection? PC tends to warping. Lifting the corners can cause a crash.
I think you are right. I can see the left side of the print that has warped. can this be avoided?
@koutso-k
Print in an enlosure (temp. about 40degree C.); switch off the nozzle fan; use glue like magigoo and a brim; reduce printing speed.
Thanks,
Any idea what printing surface and with what config does it work best for polymax?
I have both PEI and steel but never managed to print anything on the steel coated one since nothing seems to stick.
Also i had the nozzle fan at 15% since this would provide a better finish but now i know its a mistake for larger prints due to warping.
Finally i will also use a brim.
@koutso-k
polymax PC adheres best to the textured plate with adhesive such as dimafix or magigoo.
However, I would strongly advise against using polymac pc, as the components will crack or break after a short time due to heat, UV radiation and dynamic movements:
