Autodesk Inventor exporting problem
I am having a hard time with AutoDesk Inventor,
When I export my parts to .stl and load them in netfab/meshmixer/prusasilver they are always in the wrong scale.
I am designing the parts in MM so it should be a problem, but Netfab for instance scales the parts by a factor of 10.
Measurements that should be 190mm are now 19mm .. and when I try to scale the part up, it does not equal my Inventor measurements.
I think because Netfab is dropping points, ie; 172.469 becomes 17.2, so when scaled everything gets out of whack.
Anyone have this problem, a solution, or advice on how to fix this issue.
Thanks,
Lance
RE: Autodesk Inventor exporting problem
could the export profile be set to cm rather than mm?
Joan
hmm, didnt even think to check that.. figured it was the same as the document i was working with... will check when i can... thx
