Autodesk Inventor exporting problem
lance.m4
(@lance-m4)
I am having a hard time with AutoDesk Inventor,
When I export my parts to .stl and load them in netfab/meshmixer/prusasilver they are always in the wrong scale.
I am designing the parts in MM so it should be a problem, but Netfab for instance scales the parts by a factor of 10.
Measurements that should be 190mm are now 19mm .. and when I try to scale the part up, it does not equal my Inventor measurements.
I think because Netfab is dropping points, ie; 172.469 becomes 17.2, so when scaled everything gets out of whack.
Anyone have this problem, a solution, or advice on how to fix this issue.
Thanks,
Lance
Napsal : 02/06/2019 8:57 pm
RE: Autodesk Inventor exporting problem
could the export profile be set to cm rather than mm?
Joan
Napsal : 02/06/2019 9:13 pm
lance.m4
(@lance-m4)
hmm, didnt even think to check that.. figured it was the same as the document i was working with... will check when i can... thx
Napsal : 03/06/2019 1:02 am
