Auto mesh bed leveling running twice with OctPrint
DrGarbinsky
(@drgarbinsky)
When using octo print with my mk3s + mmu2s  each print runs auto mesh bed leveling twice. Once before preheating and once after.
Any idea on how to eliminate the first instance?
Posted : 06/04/2021 5:05 pm
OldCoder liked
William
(@william)
RE: Auto mesh bed leveling running twice with OctPrint
I just had this problem and just fixed it.
Go into octoprint config (wrench), then gcode scripts.
The run before printing command is set at G28
Per the Prusa official page: https://help.prusa3d.com/en/article/prusa-specific-g-codes_112173
This command in a prusa will auto home AND mesh level.
However, if you change the command in octoprint to this:
G28 W
It will skip the level part.
Then it levels just once, after preheating.
Posted : 14/04/2021 3:22 am
OldCoder liked
