ASA Filament issue
liubie
(@liubie)
ASA Filament issue
hi
I tried to print using (SUNLU ASA Filament), but found an issue (Video attachment), can I solve it? knowing that it is the first time I used this ( ASA Filement)
Best Answer by liubie:
Thank you . (MMU2) Has been canceled and the printer is normally working
Respondido : 19/04/2021 7:20 pm
Miembro
RE: ASA Filament issue
You have a jam.  Try heating it up 10 degrees warmer.  If that does not work, do a cold pull.
Respondido : 20/04/2021 10:28 am
1 les gusta
liubie
(@liubie)
hi @cwbullet
I did cold pull but the issue still, also with  filament type  PLA
Esta publicación ha sido modificada el hace 5 years por liubie
Respondido : 21/04/2021 10:54 pm
liubie
(@liubie)
Respondido : 09/05/2021 11:52 pm
