ASA Filament issue
hi
I tried to print using (SUNLU ASA Filament), but found an issue (Video attachment), can I solve it? knowing that it is the first time I used this ( ASA Filement)
Best Answer by liubie:
Thank you . (MMU2) Has been canceled and the printer is normally working
Postato : 19/04/2021 7:20 pm
RE: ASA Filament issue
You have a jam. Try heating it up 10 degrees warmer. If that does not work, do a cold pull.
Postato : 20/04/2021 10:28 am
1 persone hanno apprezzato
Topic starter
answered:
hi @cwbullet
I did cold pull but the issue still, also with filament type PLA
Questo post è stato modificato 4 years fa da liubie
Postato : 21/04/2021 10:54 pm
Topic starter
answered:
Postato : 09/05/2021 11:52 pm
