Artifacts/defects all over this MK3S print
Hi, I'm trying to print this piece but I'm getting these awful lines across the front of the print. They match to the indents on the back of the object. I've checked in the slicer and the thinnest point is four shells. Additionally there are little holes on the back despite my seams set to aligned. Also there little blobs of filament in spots around the print too.
I'm using esun cold white pla+ with a calibrated (with calipers) flow rate of 0.97. I've tried using prusament and had the same result only it had the added bonus of random under extrusion all over the place.
This is printed with 0.4 nozzle at 0.15mm.
Postato : 18/10/2020 2:27 am
