Any recommended good mod to make it easy to fix the headbed-cable-clip?
Hi, whenever I work on the electronics, I found it very difficult to tighten the two screws to fix the Heatbed-cable-clip as shown in Step 23's right photo. The reason is the thick cable bundle with textile sleeve. Any recommendation on good mod?
Prusa Knowledge Base | 8. Electronics assembly (prusa3d.com)
Opublikowany : 13/04/2022 11:45 pm
