An Error message in PrusaSlicer.. Print area
so, I3 MK3S says print area is 8.3 by 8.3 inches. I put in part 8.12 in diameter which was verified by slicer. Error message said "a tool path outside the print area was detected". What exactly am I missing... Is the print area less than 8.3 inches????? to fix do I have to cut/slice the part.
thanks for any help. New to all this ....Alan
Napsal : 30/08/2021 6:40 am
skirt
Did you try to deactivate the skirt (set it to 0)?
PS: Build volume is 9.84"×8.3"×8.3". That is 9.84" in X, 8.3" in Y and 8.3" in Z.
Napsal : 30/08/2021 6:46 am
Topic starter
answered:
Error Print area
I will look at deactivating skirt. Thank you very much.
Napsal : 30/08/2021 6:53 am
