Always beep when switch off the printer
ccc888
(@ccc888)
Hi guys,
I assembled my printer several days ago. It works well except one problem:
Every time I switch the power off, I hear a beep from the printer. The next time I power it up and check the fail statics, the power failure counter will increment by one.
I tried power the printer off with printer fully cool down, it didn't work. The only way I can shut it down without a beep is to press the reset button then switch off the power immediately. I don't think this is a normal solution.
Did anyone experienced the same issue? I live in USA and the voltage here is 120V and I'm using the latest firmware for MK3S.
Thanks for any thoughts and help
Veröffentlicht : 29/07/2019 11:18 pm
Erikp
(@erikp)
RE: Always beep when switch off the printer
I'm having the same issue. And it is not a subtle or quiet beep. Very annoying. The printer did NOT do this on the prior version of firmware. This has only been happening since I updated to the most recent version  3.7.2
I'd really like to disable it.
Veröffentlicht : 30/07/2019 4:50 pm
Dave Avery
(@dave-avery)
are you switching off by the switch on the power supply or an external power switch ?
Veröffentlicht : 30/07/2019 7:56 pm
ccc888
(@ccc888)
Posted by: david.a66
I turn it off using the power supply switch.
Veröffentlicht : 30/07/2019 8:20 pm
Erikp
(@erikp)
Same here, always by the power switch on the printer's power supply.
Veröffentlicht : 30/07/2019 9:20 pm
mlmarklamb142
(@mlmarklamb142)
I've had mine do the same thing, and it started after the latest update.
Veröffentlicht : 30/07/2019 9:31 pm
darren-1
(@darren-1)
Hello, I just completed assembly of my MK3S and it is doing the same thing. Found it odd for a loud beep when turning off the power supply from the switch. Can understand it if it is a design feature to let you know if power was lost but not from turning off the switch. Curious to see what Prusa has to say about it.
Veröffentlicht : 31/07/2019 12:47 am
OPK
 OPK
(@opk)
Any comments from Prusa? I will revert tonight to 3.7.1 as I don't want to wake up the whole house when switching the printer off.  Is the firmware not tested before it is released? 🙁
Veröffentlicht : 02/08/2019 3:40 pm
There have been many discussion here on the topic. I'm not affected, but my understanding is that:
  1. It is an issue with the newer black power supplies only. Older silver variants are not affected.
  2. They are addressing it in the next release.
Veröffentlicht : 02/08/2019 3:54 pm
OPK
 OPK
(@opk)
1. I have a Mean Well UHP350 power supply; same issue.
2. Thx for the info
Veröffentlicht : 02/08/2019 9:44 pm
