After firmware flash: Additional steps needed?
Sam
 Sam
(@sam)
I could not spot at those relevant pages at https://help.prusa3d.com/l/en/article/r5ByKgVm69-firmware-upgrade-and-flashing and https://manual.prusa3d.com/Guide/Upgrading+the+firmware+v1.4/66?lang=en whether a calibration is required after firmware flash.
Has somebody a source or updated doc link where it is clearly stated whether calibration is optional or required?
Opublikowany : 18/07/2018 6:32 pm
moojuiceuk
(@moojuiceuk)
Re: After firmware flash: Additional steps needed?
Just a simple question:
Is it recommended to re-calibrate the printer after each firmware update ?
No, you don't have to recalibrate after the FW update. If there is a need for it, for example to improve the calibration results, we will inform you 😉
Here, a forum admin has stated it's not required unless they state on the release. I personally factory reset and calibrate each time as a matter of habit, but thats just me, as I like to see if any calibration behaviour has changed from one release to the next.
Opublikowany : 19/07/2018 2:51 am
1 ludzie polubili
