After extruder jam. Prints won't stick to the bed. Help!
BillR94
(@billr94)
Had a bad filament jam I had to disassemble the hot-end to clear it and put a new E3D Nozzles, ExcelFu M6 0.4mm Brass Nozzle from ebay. I put it back together and re-calibrated the Z axis but none of the filament will stick to the bed. I never had this issue before. I tried PETG and PLA. Some parts of the bed stick, some don't. I tried glue, blue tape, hair spray as well. The only thing I changed was the nozzle. Is there a recommendation for a nozzle I should use with these MK3S+ machines?  I looked on the website bet don't see just the nozzle. Your recommendations are appreciated.
Thank you
Bill
Postato : 08/02/2023 9:09 pm
Hello
(@hello)
RE: After extruder jam. Prints won't stick to the bed. Help!
First of all glue and hair spray loosen sticking it's meant for abs of petg if it's getting to stuck to bed clean the bed with warm soapy water and scrub the bed lightly to remove grease
Postato : 11/02/2023 6:59 pm
