[Résolu] after 3.10.1 upgrade - MKs3 no complet reboot anymore
curieux
(@curieux)
I did an upgrade on my MK3S - see attach log file
After the upgrade the printer shutdown and if I switch it on and off the power the printer try to start 1 sec but boot procedure not  finishing
Also factory reset not working with the X Button
here the log
avrdude-slic3r -v -p atmega2560 -c wiring -P COM5 -b 115200 -D -U flash:w:0:D:\aa-prusa-mini&MK\Firmware\MK3S\prusa3d_fw_MK25S_3_10_1_4697_RAMBo10a_en-de.hex:i avrdude-slic3r: Version 6.3-20160220-prusa3d, compiled on Mar 10 2022 at 11:54:26 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch Using Port : COM5 Using Programmer : wiring Overriding Baud Rate : 115200 AVR Part : ATmega2560 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PA0 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00 flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00 lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : Wiring Description : Wiring Programmer Model: AVRISP Hardware Version: 15 Firmware Version Master : 2.10 Vtarget : 0.0 V SCK period : 0.1 us avrdude-slic3r: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.01s avrdude-slic3r: Device signature = 0x1e9801 (probably m2560) avrdude-slic3r: safemode: hfuse reads as D0 avrdude-slic3r: safemode: efuse reads as FD avrdude-slic3r: reading input file "D:\aa-prusa-mini&MK\Firmware\MK3S\prusa3d_fw_MK25S_3_10_1_4697_RAMBo10a_en-de.hex" avrdude-slic3r: writing flash (222754 bytes): Writing | ################################################## | 100% 42.78s avrdude-slic3r: 222754 bytes of flash written avrdude-slic3r: verifying flash memory against D:\aa-prusa-mini&MK\Firmware\MK3S\prusa3d_fw_MK25S_3_10_1_4697_RAMBo10a_en-de.hex: avrdude-slic3r: load data flash data from input file D:\aa-prusa-mini&MK\Firmware\MK3S\prusa3d_fw_MK25S_3_10_1_4697_RAMBo10a_en-de.hex: avrdude-slic3r: input file D:\aa-prusa-mini&MK\Firmware\MK3S\prusa3d_fw_MK25S_3_10_1_4697_RAMBo10a_en-de.hex contains 222754 bytes avrdude-slic3r: reading on-chip flash data: Reading | ################################################## | 100% 28.71s avrdude-slic3r: verifying ... avrdude-slic3r: 222754 bytes of flash verified avrdude-slic3r: safemode: hfuse reads as D0 avrdude-slic3r: safemode: efuse reads as FD avrdude-slic3r: safemode: Fuses OK (E:FD, H:D0, L:FF) avrdude-slic3r done.
Thank you
Any idea .
Publié : 23/03/2022 11:36 am
curieux
(@curieux)
RE: after 3.10.1 upgrade - MKs3 no complet reboot anymore
wrong hex file
I see you flashed the wrong firmware, specifically the MK2.5S version instead of MK3S+
Publié : 23/03/2022 1:13 pm
