Adjust extrusion multiplier in relation to volumetric flow rate
DavorP
(@davorp)
Hi all,
I'm printing at high volumetric flow rate (25-30mm3/sec). At 1st layer I have flow of 4mm3/sec. After that my flow rate rises into 20-30mm3/range. First layer is perfect, I notice a little underextrusion on top infil.
Parts are also lighter than estimated in PrusaSlicer.
Printing on MK3s with stock extruder and 0.6mm CHT nozzle, PETG 230ºC/bed 90ºC.
Is there a way to adjust extrusion multiplier after 1st layer?
Or even better to relate multiplier with flow rate?
Thank you Davor
Napsal : 03/02/2022 2:17 pm
