Add in-between layers Gcode to trigger camera
I would like to add some G-code on the completion of each layer that moves the head out of the way and possibly triggers an output to take a photo.
If the output is not an option, I can make a microswitch trigger when the printer is in the left-most position. Similar to done here - in Simplify3D
Posted : 08/01/2020 1:07 am
RE: Add in-between layers Gcode to trigger camera
If you are using PrusaSlicer, you can customize the before/after layer change gcode in Printer Settings / Custom G-code.
Posted : 08/01/2020 3:26 am
That is all automatic with OctoLapse, the OctoPrint plugin. Works really well too.
Posted : 08/01/2020 6:24 am
You can control some I/O ports on the Einsy with G-Codes and use them to trigger a camera. There is a nice how-to on the Prusa Blog:
https://blog.prusaprinters.org/how-to-create-beautiful-3d-print-timelapse-videos/
But it needs some soldering work
Posted : 08/01/2020 8:07 am
