ABS Sic3r PE 1.41.0 Nozzle fan not turning on
alex
 alex
(@alex-6)
Hello all
I noticed that the nozzle fan did not turn on when I printed yesterday.
In the Gcode M106 is first mentioned at line 114882 with value S76.5 (is that a valid value, .5? )
If I run the Gcode in a simulator the fan does not turn on at line 114882 (layer 55 out of 145) so something in the Gcode is wrong.
question 2: is it not a bit late to turn on the fan at layer 55?
by the way, this is straight from Slic3r default settings, only changed the infill type.
Link to Gcode as I can't attach the file for some reason.
https://guldager.one/sharing/RKi2LjTYs
Respondido : 15/10/2018 2:47 pm
Re: ABS Sic3r PE 1.41.0 Nozzle fan not turning on
Hi Alexander,
I don't print ABS Myself any more...but I thought you only use fan for bridging on ABS...
Respondido : 15/10/2018 3:54 pm
