ABS really bad surface finishing (help)
Max Bursell
(@max-bursell)
Hi everyone.
I'm trying to print with ABS. I'm never using ABS, so I don't have much experience with this material.
Does anyone know why I'm getting these ugly surface layers?
It seems to be worst at the left back area of the build plate.
the first and second picture shows the complete model. the model was printet with support material.
support material or not, it doesn't seem to make any difference. same with infill.
In the third and fourth picture, you see the same model, but the lower part has been cut away in the slicer. Therefore no support or infill are playing any roll of the results of the surface finish. The print was stopped after the very first layer was complet. already then it's clear that the ugly surfaces starts to build up. And it seems to be worse for every new layer.
Anyone know how to fix this issue?
I used the "prusa ABS" filament setting in the prusa slicer. The cooling fan is turned off.
I highly appreciate any suggestions,tips and tricks and help from everyone.
Thank you and have a nice day
Best regards
Max Bursell
Questa discussione è stata modificata 5 years fa 2 tempo da Max Bursell
Postato : 22/05/2021 10:13 am
Utenti
RE: ABS really bad surface finishing (help)
What setting are you using and are you sure it is dry?
Are you in an enclosure?
Postato : 22/05/2021 10:31 am
Max Bursell
(@max-bursell)
@cwbullet
Hi cwbullet
Thank you for your interest.
I'm using the "prusa ABS" filament setting.
The spool is brand new, just open. so it should still be dry.
I'm not using an enclosure.
but running 110 degrees on bed. and 255 on hotend
Have you ever experients the same?
Best Regards
Max Bursell
Postato : 22/05/2021 10:46 am
Utenti
@max-bursell
I have never been able to get ABS to print without an enclosure.  It just will not print without warping or any respectable quality.
What is the brand of ABS?
Postato : 22/05/2021 11:04 am
Max Bursell
(@max-bursell)
@cwbullet
Im using the 3DE premium ABS filament
Thank you so much for your help
Best regards
Max Bursell
Postato : 22/05/2021 11:29 am
Dan Rogers
(@dan-rogers)
I would suggest that it is bedded upside down.  Those first layers also look suspect (wavy like water, Z too low).
Postato : 22/05/2021 1:10 pm
Utenti
@dan-rogers
Hard to tell with the poor quality but you might be right.
Postato : 22/05/2021 1:14 pm
It looks like layer one is going down is too low (too thin).  But I'd flip the part over rather than try printing that as shown in the preview - with supports the surface will never be serviceable.
Postato : 22/05/2021 3:44 pm
1 persone hanno apprezzato
towlerg
(@towlerg)
A draft shield will help if you don't have an enclosure.
+1 for flipping the part over
Postato : 22/05/2021 5:46 pm
Swiss_Cheese
(@swiss_cheese)
@max-bursell
Can you possibly post a zipped up .3mf project file, this would allow us to stop guessing and take a look at the settings your using in conjunction with your model, and the images you have posted provide clues as well. you can post the zipped up .3mf using the in the upper corner of the reply window.  this could be a simple cooling issue, it could be layer height, wet filament, ect,,. you get the idea the .3mf really helps since we can't be sitting there with you.
Good Luck
Swiss_Cheese
The Filament Whisperer
Postato : 22/05/2021 7:46 pm
jsw
 jsw
(@jsw)
I've had good luck printing ABS on the I3 before I got the enclosure by using the Draft Shield.  It's available in both PrusaSlicer and Cura.
I do agree that the overall print quality with ABS is better and more consistent with an enclosure.
If I were printing this, I would print it with the large flat surface touching the build plate.  I would also use supports, but be sure to tweak the Z distance to .2 or .25 for 'break away' support material.
Postato : 22/05/2021 10:19 pm
Utenti
@jsw
Outside of ABS-T, I have had the same experiences.
Postato : 22/05/2021 10:41 pm
jsw
 jsw
(@jsw)
I'm really not familiar with ABS-T.  Chuck, what would you say the advantage(s) of ABS-T would be over plain old ABS?
I've seen it on the Filament-PM site, but never really considered ordering it.
Postato : 22/05/2021 10:53 pm
Utenti
@jsw
ABT-T is easier to print. ABS-T is suitable to print objects that have temperature stability into the 100°C and higher strength and hardness.  It is an acetone-soluble polymer. It does have a tendency to warp but less so than ABS.
Postato : 22/05/2021 11:20 pm
Swiss_Cheese
(@swiss_cheese)
I'd leave the part in the orientation shown in your images, it offers the best chance for success, the default support settings with a XY separation of 1.5mm will be your best bet and leave the Z contact at 0.1 for your best support they will remove just fine if your printing at 0.15mm layer height.
you have not provided a project file so basically it's anyone's guess.
P.s. @Charles ABS can be printed fine outside of an enclosure, it really depends on the models shape, size and environment your printing in, skirts and temporary/permanent enclosures can defiantly assist in ease of printing though.
Good Luck
Swiss_Cheese
Postato : 22/05/2021 11:57 pm
Utenti
@swiss_cheese
I have found that I am more successful with less warping and fumes in an enclosure.  If you can do it, congrats,  I can not.
Postato : 23/05/2021 12:01 am
Swiss_Cheese
(@swiss_cheese)
@charles
I can, however like yourself I know that an enclosure works best, it's just easier. I mention that to you specifically because while you may have had a bad experience outside the enclosure it is possible and not always difficult.  I don't want the OP thinking that it can't be done, they are new to the material and impressionable, the OP's part is a very simple low profile part and should be easy to maintain the heat around at that level without an enclosure, as towlerg mentioned the use of a skirt should handle a model like that nicely.
As for flipping it over (I know you didn't mention this) I think that's not the right way to go, if you examine the model it has long round edges and would be a much better candidate in my experience for being printed on supports in the orientation shown.
Regards
Swiss_Cheese
Postato : 23/05/2021 12:25 am
Utenti
@swiss_cheese
I concur.  You get more successful prints more often.
Postato : 23/05/2021 12:31 am
