[Risolto] A lit LCD appears squares, but without subtitles
Aharone33
(@aharone33)
After dozens of hours of printing and everything was fine, I decided to clean the printer, lubricate and strengthen and the like. Somehow the LCD display appears 2 lines with the boxes without subtitles. I tried to check if the LCD cables are well connected.- Yes well connected. So I downloaded and updated. The software says it worked well. But do not see the subtitles. What to do?
Postato : 08/04/2021 12:02 pm
AlecColsonSGC
(@aleccolsonsgc)
RE: A lit LCD appears squares, but without subtitles
If your problem is solved, congrats.
Please let us know how you solved it. It may help others.
If you selected [solved] by mistake, please look at
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/display-malfunction/#post-405775
Good luck.
"Wir blasen seit 50 Jahren unsere Fernsehprogramme ins All. Jede Zivilisation in 50 Lichtjahren Umkreis weiss, das es hier kein intelligentes Leben gibt." Prof. Michio Kaku
Postato : 11/04/2021 4:18 pm
Aharone33
(@aharone33)
One of the plugs partially came out of place. Just put it back in place and that's it.
Postato : 13/04/2021 1:51 am
