9 points calibration offset?
denis.l5
(@denis-l5)
Since some firmware updates, I noticed that the 9 points of the bed leveling have shifted to the left, and are no more centered across the bed. Is it a normal behaviour or should I do something? Thanks
Opublikowany : 08/07/2023 5:53 pm
RE: 9 points calibration offset?
If the printer has sensorless homing like the MK3 series printers. It is likely that something is stopping the X or y axis from homing properly.  Could be as simple as the smooth rods needing cleaning
Opublikowany : 08/07/2023 6:05 pm
denis.l5
(@denis-l5)
Hum, thanks Joan for your prompt answer, but everything works correctly, simply the square made by the 9 calibration points is offset to the left compared to what it used to be before (before being some firmware updates ago, say 2 or 3 updates from the last I think).
Opublikowany : 10/07/2023 3:02 pm
