9 points calibration offset?
Since some firmware updates, I noticed that the 9 points of the bed leveling have shifted to the left, and are no more centered across the bed. Is it a normal behaviour or should I do something? Thanks
RE: 9 points calibration offset?
If the printer has sensorless homing like the MK3 series printers. It is likely that something is stopping the X or y axis from homing properly. Could be as simple as the smooth rods needing cleaning
Hum, thanks Joan for your prompt answer, but everything works correctly, simply the square made by the 9 calibration points is offset to the left compared to what it used to be before (before being some firmware updates ago, say 2 or 3 updates from the last I think).
