7x7 Mesh Bed Leveling starting from Right to Left all of a sudden??
Walt
 Walt
(@walt)
Hi All. After several years of firing up my MK3S+, and it doing its mesh bed levelling routine where the extruder and pinda move across the build plate from Left to Right, Front to Back; it has now decided to do this in reverse order ie. moving all the way across the front of the build plate and then starting its check in the far right , front corner of the build plate and then moving to the left. I'm running Prusaslicer 2.9.0, and firmware updates are up to date as of a couple of months ago.
So my question is... What has changed? Has there been a change to the software? Are the measurements now problematic? I'm asking as I'm at the moment now all of a sudden also dealing with bed adhesion problems with corners of prints lifting on a smooth plate. This could be a coincidence, but the change in travel of the pinda/extruder is an open question for me. Does any else have experience with this.
All help / advice greatly appreciated! Cheers, Walt
Respondido : 14/06/2025 12:13 pm
