3x3 Mesh is good - 7x7 Mesh so bad
Anuvaris
(@anuvaris)
Hey Guys,
my 7x7 mesh is horrible!
when i level my bed with the 3x3 mesh everything is fine. I uploaded 3 pictures of the Octoprin Prusa Bed Leveling Guide Plugin - seems like a litte kind of measuring variance. I didnt change anything.
Same result with the bed leveling visualizer:
But when i switch to the 7x7 mesh and check it it looks horrible!!!
Here is my nut setup.
And this is how my bed looks like:
If you have any idea how this can happen and how i can fix it id be really greatful
Thanks a Lot
Anuvaris
Veröffentlicht : 06/04/2022 4:13 pm
Anuvaris
(@anuvaris)
RE: 3x3 Mesh is good - 7x7 Mesh so bad
-bump up-
Veröffentlicht : 19/04/2022 6:39 pm
Robin
(@robin)
Mh, a maximum variance of 0.044 over a few measurements is very good. So, as long as you don't have any first layer issues: why bothering with the 7x7 mesh results? Since the shape of the 7x7 mesh is quite different than the 3x3 even though it is the same physical bed, I'd suggest you just blame it on measurement errors (for example caused by the magnets in the bed. They are the reason your printer does not use all 7x7 measurements for bed leveling unless you force it to) and be happy with it.
Veröffentlicht : 20/04/2022 3:32 pm
