3M 468MP 200MP Removal tip
pci06
(@pci06)
I would like to suggest you an easier way to remove the adhesive by using a steel bar where you roll-up the adhesive and then remove it like you open tin can 😉
You firstly pull-up a corner with a suffisent length and then you place an adhesive tape in order to fix the corner to the bar and then you open the tin can 🙂
I've twisted the bar on both ends in order to have handles on the same plan. (My bar diameter is 8mm)
pci.
MK3 kit.
Opublikowany : 22/06/2018 3:10 pm
Re: 3M 468MP 200MP Removal tip
This is to remove the PEI sticker from the print bed, correct?
Opublikowany : 22/06/2018 3:41 pm
pci06
(@pci06)
Yes 🙂
It works great, and i've also put the plate in a bag with paper around soaked of turpetine (less expensive than D-Limonene) about 30mn. The glue transforms in a kind of jelly.
MK3 kit.
Opublikowany : 22/06/2018 4:23 pm
Chris
(@chris-16)
i was just going to post about the economics of replacing the sheets.
So far I have spent
$18 plus $10 shipping for 2 sheets of PEI
$8 for 4 oz of limonene which got about 2/3rds of the glue off
$20 for 16 oz of limonene to get the rest off
even if it was $1 for the solvents it would be much cheaper to just buy another sheet, especially when the powder coated sheets become available.
I do not think I will ever, ever replace the pei stickers ever again.
Opublikowany : 24/06/2018 2:34 am
Good observation Chris...
Opublikowany : 24/06/2018 2:45 am
pci06
(@pci06)
Just try to buy another one😉
For now they are not available😉
I've found 5 PEI sheets for about 20€
I've used about 50cl of turpetine (4€), it was m'y first time.
A steel bar (<10€) (I will reuse it)
4+4+10<30
Next time it will be:
4+4<30
But I agree with you, it's better to buy another one.
MK3 kit.
Opublikowany : 24/06/2018 2:50 am
Chris
(@chris-16)
4+4+10<30
4+4<30
if you look around in the forum there are posts from people who have received the textured sheet, and it's not $30 it is $25.
as far as the pei you've found be careful of the thickness. when i went searching i couldn't find sheets with the same adhesive and the same thickness for any less.
i'd rather have the powder coated than these sheets any day.
Opublikowany : 27/06/2018 7:55 am
