3.4.0 Pause print nozzle not heating up on resume
I just paused a print on the first layer cause I saw some ooze stuck on the side of the nozzle.
It paused after finishing some movements (the skirt) and then moved Z up, moved Y forward, X to the left and turned of the nozzle heat.
Then when I pressed resume after just 20 seconds or so it displayed heating... (with the periods moving) the bed stayed the same temperature all the time, but the nozzle was still set to 0...
I waited a while to see if it was just waiting for the bed to stabilize or something but after 1 min it still didn't heat the nozzle.
Has anyone else had this happen? Is it a bug in the firmware? Did I not wait long enough?
Postato : 22/09/2018 1:02 pm
