3.2.0 (Final) Firmware for Prusa i3 MK3 / MK2.5 is out!
Just to let you know, final version of 3.2.0 firmware is out:
Grab the link: https://github.com/prusa3d/Prusa-Firmware/releases
Problems with Z calibration should be solved.
Veröffentlicht : 09/05/2018 8:48 pm
Re: 3.2.0 (Final) Firmware for Prusa i3 MK3 / MK2.5 is out!
How do you know which firmware load to use?
Thanks
MK3 Kit, Designed, built 4x4 CNC Plasma Cutting Table, Motorcycles Bigdogbro's Adventures
http://www.youtube.com/channel/UC5djrxBeeOKB9_6rHnn6G8A
Veröffentlicht : 11/05/2018 1:31 pm
Thanks
They are identified per machine "MKx" - you need the third one in the list, I believe, the one with "MK3" in it.
Veröffentlicht : 11/05/2018 1:34 pm
Geez, I must be blind....Thanks!
Veröffentlicht : 12/05/2018 2:33 pm
