3.14.0 update keeps showing "sliced for a different printer" warning
RayRay
(@rayray)
Printer is a MK3S/MMU2S updated to 3.14.0/3.0.2, PrusaSlicer 2.8.0 setting is MK3SMMU2S, however I keep getting the sliced for a different printer error. I know I can just click continue every time, just wondering if there's a fix, I assume either the printer or the slicer profile has something wrong.
Publié : 08/08/2024 1:37 am
1 personnes ont aimé
BcreaTv
(@bcreatv)
Membre
RE: 3.14.0 update keeps showing "sliced for a different printer" warning
i would also like to know the fix for this!
Publié : 17/08/2024 2:05 am
Wheart
(@wheart)
Same problem: MK3S with SuperPINDA, MMU2S, PrusaSlicer 2.7.4
Over USB in PrusaSlicer printer is recognized as MK3 (PrusaSlicer 2.4.x used for flashing, if it changes anything)
In support menu: 1_75_MK3S
Prints without a problem.
Publié : 24/08/2024 9:46 pm
Wheart
(@wheart)
I've also did some checking:
  • all three variant of firmware ZIPs contain same HEX file for MK3S/S+, regardless of standalone/MMU2s/MMU3 versions
  • MMU firmware for MMU2s and MMU3 is same
How printer knows, which MK3/MMU variant it actually is?
Publié : 24/08/2024 9:57 pm
shamstead
(@shamstead)
Membre
Running into the same issue and have resolved that the printer is looking for "MK3SMMU3" and PrusaSlicer is generating "MK3SMMU2S".  For the time being, I turned off the model check in the printer's settings.
I've also posted this in a different thread I found before this one: https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/g-code-sliced-for-a-different-printer-type-continue/#post-720398 (Sorry for double posting)
Does anyone know if there are any detrimental effects of installing the printer in PrusaSlicer as an MK3S+ with MMU3 instead of MK3S+ with MMU2S (which I assume will resolve the mismatch message)?
Publié : 30/08/2024 3:18 pm
rjrosa
(@rjrosa)
Membre
Similar situation here. I have a MK3S/MMU2S (Upgraded from MK3 / MMU2).
I used to print with the "Original Prusa i3 MK3S & MK3S+ MMU2S Single" configuration.  But after upgrading to 3.14.1 / MMU 3.0.3 I got the same "sliced for a different printer" error as above.
Based on the above discussion, I changed the printer setting to "Original Prusa i3 MK3S & MK3S+ MMU3 Single" configuration.  I've printed 2-3 things so far and everything seems to work well so far with this setting.
(Note that I had this issue after upgrading the firmware that I'll post about later: https://www.reddit.com/r/prusa3d/comments/15d442e/new_mmu2s_firmware_issue/ )
Ce message a été modifié il y a 1 year 2 fois par rjrosa
Publié : 17/12/2024 3:30 am
